PBS Pro qsub Options¶
Version 1.2 2021-04-28
-l select and similar options use a lowercase "L", -I for interactive is an uppercase "I".
| Cobalt CLI | PBS CLI | PBS Directive | Function and Page Reference |
-A <account_string> | -A <account_string> | #PBS Account_Name=<accounting string> | "Specifying Accounting String” UG-29 |
-n NODES--nodecount NODES | -l select=NODES:system=<hostname> | One or more #PBS -l <resource name>=<value> directives | "Requesting Resources” UG-51 |
-t --walltime | -l walltime=H:MM:SS | One or more #PBS -l <resource name>=<value> directives | "Requesting Resources” UG-51 |
--attrs filesystems=<resource> | -l filesystems=<resource> | One or more #PBS -l <resource name>=<value> directives | "Requesting Resources” UG-51 |
-q | -q <destination> | #PBS -q <queue name> #PBS -q @<server name>#PBS -q <queue name>@<server name> | "Specifying Server and/or Queue” UG-29 |
--env | -v <variable list> | "Exporting Specific Environment Variables” UG-126 | |
--env | -V | #PBS -V | "Exporting All Environment Variables” UG-126 |
--attrs | Done via custom resources and select statements | "Setting Job Attributes” UG-16 | |
--dependencies=<list> | -W depend=afterok:<list> | #PBS depend=... | "Using Job Dependencies” UG-107 |
-I--interactive | -I | Deprecated for use in a script | "Running Your Job Interactively” UG-121 |
--jobname | -N <name> | #PBS -N <job name> #PBS -WJob_Name=<job name> | "Specifying Job Name” UG-27 |
-e--error= | -e <path> | #PBS -e <path>#PBS Error_Path=<path> | "Paths for Output and Error Files” UG-42 |
-o--output= | -o <path> | #PBS -o <path>#PBS Output_Path=<path> | "Paths for Output and Error Files” UG-42 |
-M--notify see note #1 | -M <user list>-m <mail options>( -m be is suggested) | #PBS -M <mail recipients> #PBS -WMail_Users=<mail recipients>#PBS -m <mail points> #PBS -WMail_Points=<mail points> | "Setting Email Recipient List” UG-26 |
-u--umask | -W umask=<value> | #PBS umask=<value> | "Changing Linux Job umask” UG-45 |
-h | -h | #PBS -h | "Holding and Releasing Jobs” UG-115 |
--proccountSee Note #2 | -l mpiprocsNot needed to get equivalent Cobalt functionality | One or more #PBS -l <resource name>=<value> directives | "Requesting Resources” UG-51 |
PBS options that provide functionality above and beyond Cobalt¶
Depending on policy decisions, not all of these options may be available.
| N/A | -a <date_time> | #PBS -a | "Deferring Execution” UG-119 |
| N/A | -C <directive prefix> | "Changing the Directive Prefix” UG-16 | |
| N/A | -c <interval> | #PBS -c | "Using Checkpointing” UG-113 |
| N/A | -G | "Submitting Interactive GUI Jobs on Windows” UG-125 | |
| N/A | -J X-Y[:Z] | #PBS -J | "Submitting a Job Array” UG-150 |
| N/A | -j <join> | #PBS Join_Path=<joining option> | "Merging Output and Error Files” UG-43 |
| N/A | -k <keep> | #PBS Keep_Files=<keep option> | "Keeping Output and Error Files on Execution Host” UG-44 |
| N/A | -p <priority> | #PBS -p | "Setting Priority for Your Job” UG-120 |
| N/A | -P <project> | #PBS project=<project name> | "Specifying a Project for a Job” UG-27 |
| N/A | -r <value> | #PBS -r | "Allowing Your Job to be Re-run” UG-118 |
| N/A | -R <remove options> | "Avoiding Creation of stdout and/or stderr” UG-43 | |
| N/A | -S <path list> | "Specifying the Top Shell for Your Job” UG-19 | |
| N/A See Note #3 | -u <user list> | #PBS User_List=<username list> | "Specifying Job Username” UG-28 |
| N/A | -W block=true | #PBS block=true | "Making qsub Wait Until Job Ends” UG-120 |
| N/A | -W group_list=<list> | #PBS group_list=<group list> | "Specifying Job Group ID” UG-28 |
| N/A | -W release_nodes_on_stageout=<value> | "Releasing Unneeded Vnodes from Your Job” UG-127 | |
| N/A | -W run_count=<value> | "Controlling Number of Times Job is Re-run” UG-119 | |
| N/A | -W sandbox=<value> | "Staging and Execution Directory: User Home vs. Job-specific” UG-31 | |
| N/A | -W stagein=<list> | #PBS -W stagein=<execution path>@<input file storage host>:<input file storage path>[,...] | "Input/Output File Staging” UG-31 |
| N/A | -W stageout=<list> | #PBS -W stageout=<execution path>@<output file storage host>:<output file storage path>[,...] | "Input/Output File Staging” UG-31 |
| N/A | -X | "Receiving X Output from Interactive Linux Jobs” UG-124 | |
| N/A | -z | #PBS -z | "Suppressing Printing Job Identifier to stdout” UG-30 |
Notes¶
- To get the equivalent mail notifications from PBS, it requires two parameters: the
-Mjust like Cobalt, but also-m be(thebestands for "beginning" and "end") to specify when the mails should go out. This will give you the same behavior as Cobalt. --proccount, while available, only changed behavior on the Blue Gene machines. To get equivalent functionality, just drop it from the CLI. In PBS, it does influence thePBS_NODESfile. See Section 5.1.3 in the PBS Users Guide page UG-78.- The following Cobalt options have no equivalent in PBS:
--cwd: use a script andcdto the directory you want to run from.--user_list: There is no way to do this. We will work on adding this functionality.--debuglog: Are we going to try and generate the equivalent of a.cobaltfile?
- The following Cobalt options were Blue Gene specific and no longer apply:
--kernel-K KERNELOPTIONS--ion_kernel--ion_kerneloption--mode: see notes on running scripts, Python, and other executables--geometry--disable_preboot
