Job and Queue Scheduling on ThetaGPU
Queues and Job Scheduling
General Policy
We ask that all users follow good etiquette and be kind to one another.
Job Priority
As with all Argonne Leadership Computing Facility production systems, job priority in the queue is based on several criteria:
- positive balance of your project
- size (in nodes) of the job, larger jobs receive higher priority
- the type of project (e.g. INCITE, ALCC, or discretionary)
- job duration - shorter duration jobs will accumulate priority more quickly, so it is best to specify the job run time as accurately as possible
Reservations and Scheduling Policy
Some work will require use of Theta that requires deviation from regular policy. On such occasions, normal reservation policy applies. Please send the regular form no fewer than five (5) business days in advance.
Monday Maintenance
When the ALCF is on a regular business schedule, preventitive maintenance is typically scheduled on alternate Mondays. The showres command may be used to view pending and active maintenance reservations.
Big Run Mondays
As part of our regular maintenance procedures on Mondays, we will promote to the highest priority any jobs in the queued state requesting 802 nodes or more (.ie. capability jobs). Promotion is subject to operational discretion.
We may also, at our discretion, take the opportunity to promote the priority of capability jobs if the system has been drained of jobs for any other reason.
INCITE/ALCC Overburn Policy
If an INCITE or ALCC project has exhausted its allocation in the first 11 months of its allocation year, it is eligible for overburn running. At this point, capability jobs submitted by INCITE and ALCC projects will run in the default queue (instead of backfill) for the first 11 months of the allocation year until 125% of the project allocation has been consumed. Note that non-capability jobs will be routed to backfill queue.
INCITE and ALCC projects needing additional overburn hours should e-mail support@alcf.anl.gov with a short description of what they plan to do with the additional hours, highlighting specific goals or milestones and the time expected to accomplish them. This will be reviewed by the scheduling committee, allocations committee, and ALCF management. Requests should be submitted 15 days before the start of the next quarter of the allocation year for full consideration. Non-capability jobs from projects that have exhausted their allocation will continue to run in backfill.
To be clear, this policy does not constitute a guarantee of extra time, and we reserve the right to prioritize the scheduling of jobs submitted by projects that have not yet used 100% of their allocations, so the earlier that an INCITE or ALCC project exhausts its allocation, the more likely it is to be able to take full advantage of this policy.
ThetaGPU Node Queues
Note: Users will need an allocation on ThetaGPU to utilize the GPU nodes. Request for an allocation by filling out this form: Allocation request. ThetaGPU is listed under Theta on the form.
The GPU nodes are new and we expect the workload to be significantly different than it is on the KNL nodes. This document describes the current state of affairs, but we will monitor usage and adjust the policies as necessary.
Nodes vs Queue vs MIG mode
The GPU nodes are NVidia DGX A100 nodes and each node contains eight (8) A100 GPUs. You may request either entire nodes, or a single GPU based on your job needs. What you will get is determined by the queue you submit to (See Queues section below). If it has node in the name, you will get nodes. If it has GPU in the name, you will get a single GPU. Note that if you need more than a single GPU, you should submit to the full-node queue.
Additionally, the Nvidia A100 GPUs support a feature called “Multi-Instance GPU” (MIG) mode. This allows a single GPU to be shared by up to 7 different processes. We do not schedule at this level, but to use MIG capabilities, you may pass –attrs mig-mode=True
in with your qsub and use the nvidia-smi_mig
command (note the UNDERSCORE) just as you would calling nvidia-smi mig ...
directly. Attempts to call nvidia-smi mig ...
(no underscore) directly will result in an error message. The single-gpu host will, by default, not create an MIG instance and users will have direct access to the gpu. If you are not using MIG mode, your session will appear as if it were a normal full-node system with only one gpu. Note that as of 12/13/21, MIG mode is unavailable for full-node jobs.
Queues
There are three primary queues:
- full-node: This is the general production queue for jobs that require full nodes. The -n parameter in your qsub will match the resource type in this queue i.e. -n 2 in node queue will get you two full nodes.
- bigmem - 2 of the nodes have 640 GB of memory compared to the other 22 nodes with 320 GB. Use this queue to access these 2 nodes by specifying -q bigmem
in your script. A max of 2 nodes (-n 2) can be requested in this queue.
- single-gpu: This is the general production queue for jobs that operate best on a single GPUs. The -n parameter in your qsub should always be 1 as you can only submit to a single gpu. If you need more than 1 gpu, use the full-node queue.
Here are the initial queue limits. You may not violate either of these policies.
full-node queue:
- MinTime is 5 minutes
- MaxTime is 12 hours
- MaxQueued will be 20 jobs
- MaxRunning will be 10 jobs
bigmem queue:
- MaxQueued is 2 jobs
- MaxRunning is 1 job
single-gpu queue:
- MaxTime is 1 hour
- MaxQueued is 1 job
The initial queue policy will be simple First-In-First-Out (FIFO) based on priority with EASY backfill.
Running Jobs On ThetaGPU
Running on multiple GPU nodes
Until there is tighter integration of Cobalt and mpirun on GPU nodes, the user will have to identify the nodes Cobalt assigned to their job and pass them as options to mpirun along with some other mpirun options. The following shows 2 different code snippets on how to get the hosts allocated to the job and pass them to mpirun.
option 1 - simplest
- mpirun -hostfile $COBALT_NODEFILE -n 16 -npernode 8 mpi-example-code
- where $COBALT_NODEFILE is a file that the -hostfile option can use.
option 2 - little more complicated
- HOSTS=$(cat $COBALT_NODEFILE | sed ':a;N;$!ba;s/\n/,/g')
- mpirun --np 16 --host $HOSTS --oversubscribe ./mpi-example-code
To specifically see how the MPI ranks were assigned, one could add --display-map --display-allocation to the mpirun options.
Controlling which Cobalt instance (GPU) for my commands
IF YOU ARE ONLY USING KNL NODES NOTHING CHANGES AND YOU CAN IGNORE THIS
Because of the difference in architectures and limitations in Cobalt V1, we are running two Cobalt instances, the existing one for the KNL nodes, which remains as is, and a second one for the GPU nodes. You need to be able to control which instance you are interacting with and there are several ways to do so.
- As was true in the past, if you do nothing, the commands will default to the architecture associated with the host you are on when you issue it
- If you are on the Theta login nodes, commands will default to the KNL instance.
- If you are on a GPU node, for instance the build nodes, then commands will default to the GPU instance.
- You can set an environment variable to control which instance the default commands (qsub, qstat, etc) will interact with. The primary use case here will be users who only use GPU nodes, but are working from the Theta login nodes. To do so, you may:
- module load cobalt/cobalt-knl
which would make cobalt commands interact with the original Cobalt instance and launch jobs on the KNL nodes
- module load cobalt/cobalt-gpu
which would make Cobalt commands interact with the new Cobalt instance and launch jobs on the GPU nodes
- you can also set COBALT_CONFIG_FILES=
You can use suffixed commands to explicitly control which instance you are interacting with. If you regularly use both types of nodes, this is the recommended path to avoid confusion and to prevent launching jobs on the wrong architecture.
All the commands you are used to are there, they take the same command line parameters, etc., they just have either -knl or a -gpu suffix on them. For instance:
- qsub-knl
Requesting DGX nodes or individual GPUs
The DGX nodes, which contain (8) A100 GPUs, are extremely powerful and it can be very difficult for a single job to efficiently use an entire node. For this reason, you may request either full nodes (all 8 GPUS) or individual GPUs. What you are assigned (a node or a GPU) is dependent on the queue you submit to:
- If the queue name ends in -node, you will get full nodes (8 A100 GPUs)
- If the queue name ends in -gpu, you will get an individual GPU
- The -n parameter on the qsub is the number of resources of the type in that queue. So, for example:
- qsub -n 2 -q full-node <rest of command line>
would get you two full DGX nodes, which would be a total of (16) A100 GPUs
- qsub -n 2 -q single-gpu <rest of command line>
would get you two A100 GPUs
For reservations, you can only have one queue, and the resources in the queue need to be consistent, so your entire reservation must be in nodes or GPUs. If you need both, you will need two reservations, one for each type of resource.
- Node names are of the form thetagpu## where ## ranges from 01 to 24. This is an entire node (8 GPUs)
- GPU names are of the form thetagpu##-gpu# where the GPU numbers range from 0-7.
Multi-Instance GPU (MIG) mode
The A100 GPUs have a capability known as Multi-Instance GPU (MIG). This allows you a single A100 GPU to be reconfigured at a hardware level down to a maximum of 7 instances. The valid configuration are shown in a table on the MIG page referenced above. These instances appear as a GPU to the application. In order to use this feature, the GPU must be put into MIG mode and this requires a reset of the GPU. At the current time, we are not supporting scheduling at the MIG level. However, a user can request that their GPU be put in MIG mode and then they can reconfigure the GPU into a supported configuration from their job script.
If you wish to have the resources you have requested put into MIG mode you can add either of these to your qsub command line: --attrs mig-mode=True
Details of a job submission
Details of the job submission are recorded in the <jobid>.cobaltlog
. This file contains the qsub command and environment variables. The location of this file can be controlled with the qsub --debuglog <path>
that defaults to the same place as the .output
and .error
files.
Jobs stuck in "starting" state
If you submit a job and qstat shows it in "starting" state for 5 minutes or more, most likely your memory/numa mode selection requires rebooting some or all of the nodes your job was assigned. This process takes about 15 minutes, during which your job appears to be in the "starting" phase. When no reboots are required, the "starting" phase only lasts a matter of seconds.
"utime" and "stime"
At the bottom of a
#COBALT
directives on the second line of job script
If #COBALT
directives are used inside a job submission script, then they must appear at the topmost lines of the script. #COBALT
directives following a blank line will be ignored. Attempting to qsub the following example script will lead to the error message below.
> cat submit.csh #!/bin/csh #COBALT -n 2 -t 2:00:00 -q full-node mpirun -np 20 -npernode 10 ./my_app > qsub submit.csh Usage: qsub.py [options] [] Refer to man pages for JOBID EXPANSION and SCRIPT JOB DIRECTIVES. No required options provided
> cat submit.csh
#!/bin/csh
> qsub submit.csh
12345
Job Submission on ThetaGPU
The queuing system used on ThetaGPU is Cobalt. On ThetaGPU, Cobalt jobs may run either as script jobs or interactive mode jobs.
Script Method
In the script method, Cobalt will execute a user-supplied script when running a user’s job. Following are the required flags to qsub
, as well as some of the more common options. A complete list of options may be found as a part of the qsub
manpage, available on any login node.
Required Flags
-n NN - number of nodes (-n 16 for 16 nodes)
-t time - running time (-t 30 for 30 minutes, -t 01:10:20 for 1 hr 10 min 20 sec)
-A Project - project (-A YourProject)
Common options
--attrs - you may specify additional attributes for your job.
Multiple attribute key-value pairs are colon-delimited.
The following are common on the KNL nodes:
- filesystem: a comma-separated list of filesystems used while running your job
- location: a comma-separated list of node ids. Ranges may be hyphenated.
- mcdram: The desired MCDRAM mode of a job (default: cache)
- numa: The desired NUMA mode of a job (default: quad)
The following are common on the GPU nodes:
- location: a comma-separated list of node names (not IDs). Ranges may NOT be hyphenated on the GPU nodes.
- mig-mode: Should the GPUs be put in Multi Instance GPU (MIG) mode (default: False)
- pubnet: Enable public network connectivity from compute nodes
See: https://docs.nvidia.com/datacenter/tesla/mig-user-guide/index.html
--env VAR1=1:VAR2=2:… - specify required environment variables
-i file - give a file name to be used for stdin
-O Name - name your job and stdout/stderr (-O Job1)
-q queue - queue name (full-node, single-gpu, bigmem) (default: full-node)
Users will need an allocation on ThetaGPU to utilize the GPU nodes. Request for an allocation on ThetaGPU bthrough our Director's Discretionary award. ThetaGPU is listed under Theta on the form.
Users will need to load the cobalt/cobalt-gpu
module before issuing a qsub
command to access ThetaGPU.
Example Script
qsub -A YourProject -n 4 -t 30 -q full-node \
--env MYVAR=value1 -i inputdata -O Project1_out \
–attrs filesystems=home,eagle \
program.exe progarg1
Interactive Method
To run an “interactive mode” job on ALCF Cray resources, add the “-I” (uppercase "i", not a lowercase "L") flag or “--mode interactive” to your qsub line and omit any executable. Your qsub submission will then wait until nodes are allocated to your job and Cobalt will start a shell on a job-launch node on your behalf. You may aprun against your assigned resources and run other interactive commands from this node. It is important to note that your shell is executed from a launch node and not from your compute head-node. Once your allocation ends, all apruns will be terminated, but your shell will remain for any cleanup actions that you choose to take.
Ensemble Jobs
Users may run an “ensemble job” and combine runs into a single script. This can provide major enhancements to throughput, especially for large ensemble jobs. Users may run multiple jobs in sequence or may use multiple backgrounded apruns to subset their resources among multiple backend executables. There is a system limitation of 1000 simultaneous apruns per Cobalt script job.
Submitted Job with the Wrong Arguments
If you submit a job with the wrong arguments, you can modify without deleting it and resubmitting it. Most settings can be changed using qalter
Example
Usage: qalter [-d] [-v] -A <project name> -t <time in minutes>
--attrs filesystems=<filesystem>
-e <error file path> -o <output file path>
--dependencies <jobid1>:<jobid2>
-n <number nodes of> -h --proccount <processor count>
-M <email address> <jobid1> <jobid2>
qmove
Changing Executable after Job Submission
When a job is submitted via qsub, Cobalt records the path to the executable or script, but it does not make a copy. As a result, if the executable or script is modified when there is a deletion or modification, it will affect any jobs already submitted that use that executable. To avoid confusion, it is generally best to avoid making changes after job submission.
Holding and Releasing Jobs
User Holds
To hold a job (prevent from running), use qhold
. This will put the job in the user_hold
state.
user_hold
) state, use qrls
A job may also be put into a user hold immediately upon submission by passing qsub
the -h
flag.
Dependency Holds
For jobs in the dep_hold
or dep_fail
state, see the section on job dependencies.
Admin Holds
Jobs in the state admin_hold
may be released only by a system administrator.
MaxRun Holds
Jobs may temporarily enter the state maxrun_hold
if the user has reached the limit of per-user running jobs in a particular queue. No action is required; as running jobs complete, jobs in the maxrun_hold
state will be automatically changed back to queued and eligible to run.
Job Dependencies
To submit a job that waits until another job or jobs have completed, use the dependencies argument to qsub. For example, to submit a job that depends on job 12345:
For multiple dependencies, list and separate with colons.qsub -n 2 -t 30 -A yourproject --attrs filesystems=theta-fs0,grand,home --dependencies 12345:12346 a.out
dep_hold
until all the dependencies are fulfilled, then will proceed to the state queued.
Note: In the event any of the dependencies do not complete successfully (nonzero exit status), the job will instead go into the state dep_fail
. To manually release a job that is in either dep_hold
or dep_fail
Customizing the Output of qstat
Default fields displayed by the qstat
command may be changed by setting the QSTAT_HEADER
environment variable.
export QSTAT_HEADER="JobID:JobName:User:WallTime:RunTime:Nodes:State:attrs:Queue""
qstat
JobID JobName User WallTime RunTime Nodes State attrs Queue
104927 N/A user1 02:00:00 01:20:45 128 running {'numa': 'quad', 'mcdram': 'cache'} backfill
104941 N/A user2 00:20:00 N/A 2048 queued {'numa': 'quad', 'mcdram': 'flat'} backfill
104934 xxxx.yyyyy user3 04:00:00 01:10:12 32 running {'numa': 'quad', 'mcdram': 'cache'} default
104948 Xxx-YY_ZZ user4 02:00:00 00:15:03 128 running {'numa': 'quad', 'mcdram': 'cache'} default
104919 aaaaa_0000_bbbb_c user5 06:00:00 01:50:21 64 running {'numa': 'quad', 'mcdram': 'cache'} default
104945 aaaa_bb_cccc-d_eee_f.hhhhhh.iiii user6 06:00:00 00:18:25 100 running {'numa': 'quad', 'mcdram': 'cache'} default
104848 bbbbbb user7 01:00:00 N/A 3624 queued {'numa': 'quad', 'mcdram': 'cache'} default
--header
flag to qstat
Available field names can be seen by entering qstat -fl <jobid>
for any current jobid.
Redirecting Standard Input
To redirect the standard input to a job, do not use the <
redirection operator on the qsub
command line. This simply redirects standard input to qsub
, not the job itself. Instead, use the qsub option -i
# WRONG
qsub -t 10 -n 1 --attrs filesystems=home a.out < my_input_file.dat
# RIGHT
qsub -t 10 -n 1 --attrs filesystems=home -i my_input_file.dat a.out
Project Names
You can find active project names that your account is associated with by running the command:
If an account is associated with more than one project, a job must be submitted by using a specific project name using-A
or by setting the environment variable COBALT_PROJ
Sbank
The sbank database is updated hourly. This means transactions against your account can take up to an hour before they show up.
Submitting into Backfill Nodes
Sometimes the scheduler will try to clear up room for a large job. During these times, although not many jobs may be running, new jobs are not being scheduled as expected.
At such times, backfill nodes may be available. While nodes are being drained for a larger job, other user jobs may be backfilled onto these resources, provided that their requested wall time is less than the remaining drain time of the set of resources. For instance, suppose that 16 nodes are being drained to allow a 16-node job to run. Of the 16 nodes, perhaps eight are empty and the other eight are running an eight-node job that has 2 hours of wall time left. This allows the opportunity to run a 2-hour, eight-node job in the backfill here.
To discover available backfill, run the nodelist command. This command can only be run on the service nodes (thetagpusn1-2
), it cannot be run on the compute nodes.
Example
nodelist
Host Queue State Backfill
thetagpu16 CompBioAffin:backfill:full-node down -
thetagpu16-gpu0 single-gpu idle -
thetagpu16-gpu1 single-gpu allocated -
thetagpu16-gpu2 single-gpu allocated -
thetagpu16-gpu3 single-gpu allocated -
thetagpu16-gpu4 single-gpu idle -
thetagpu16-gpu5 single-gpu idle -
thetagpu16-gpu6 single-gpu idle -
thetagpu16-gpu7 single-gpu idle -
thetagpu17 CompBioAffin:backfill:full-node allocated -
thetagpu17-gpu0 single-gpu down -
thetagpu17-gpu1 single-gpu down -
thetagpu17-gpu2 single-gpu down -
thetagpu17-gpu3 single-gpu down -
thetagpu17-gpu4 single-gpu down -
thetagpu17-gpu5 single-gpu down -
thetagpu17-gpu6 single-gpu down -
thetagpu17-gpu7 single-gpu down -
Submitting to Specific Nodes
In rare cases, there may be a need to target specific hardware. This may be accomplished using --attrs location=
Example
This will force the job to run on those specific nodes. Should that location become unschedulable, for instance, due to a failed node, the job will not be allowed to run anywhere else, without resetting the location attribute. If more nodes are specified in the location field than are required to fill a job’s requested node count, then the first n nodes available in the location set will be used.Running with a Group of Users
Sometimes it is useful to allow other users to run Cobalt commands on a given job such as qhold
, qrls
, or qdel
. A list of users can be allowed to run commands on your job by submitting a list of users to qsub
, cqsub
, or qalter
using the flag --run_users
. Specified users need not be in the same project under which the job was submitted.
Example
qsub -t 10 -n 16 --attrs filesystems=grand,eagle,home location=thetagpu01:thetagpu02 --run_users frodo:sam:pippin myprog.exe
--run_project
flag.
Users who have been added to the list can run any command that the job-submitter could run on a job. This includes qhold
, qrls
, qalter
, and qdel
Group Running and File System Groups
While setting this list of users allows any of the listed users to run Cobalt commands on a job, it does not do anything about the permissions of any files involved with the job. Those must be handled by the user(s) setting appropriate permissions on their directories to allow users in their group to read and write files as appropriate. If your project needs a group on the file system to share files or a user needs to be added, email User Support.
More Information
For more information on Cobalt commands, their options, consult the manpages on the system. The same information may be found online in the Cobalt Command Reference.
Using the Job Resource Manager: Commands, Options, and Examples
This document provides examples of how to submit jobs on our systems. It also provides examples of commands that can be used to query the status of jobs, what partitions are available, etc. For an introduction to using the job resource manager and running jobs on ThetaGPU, see Running Jobs on ThetaGPU.
Submit a Job Request
Use qsub
to submit a job. Unlike jobs on the ALCF Blue Gene systems, all jobs on ThetaGPU are either script or interactive.
Run the script jobscript.sh
with 2 nodes for a maximum of 15 minutes:
qsub -q <queue_name>
Charge a Job to a Project
Use qsub -A <project_name>
to charge a job to a particular project.
To run jobscript.sh
with 2 nodes for a maximum of 15 minutes and charge the job to MyProject:
COBALT_PROJ
to set your default project. qsub -A takes precedence over COBALT_PROJ
Delete a Job from the Queue
To delete a job from the queue, use the qdel command. For example for job with ID of 34586.
Depending on the stage of a job’s lifetime, qdel may not complete immediately, especially if the delete is issued during startup on a job that is changing memory modes and rebooting a node. If the job does not ultimately terminate, contact support@alcf.anl.gov with the jobid so that an administrator can take appropriate cleanup actions and administratively terminate the job.Query Partition Availability
To determine which partitions are currently available to the scheduler, use the nodelist command. This command provides a list of node ids, names, queue, and state as well as any backfill windows. This command can only be run on the service nodes (thetagpusn1-2
For example on thetagpusnX
it displays:
thetagpu18 CompBioAffin:backfill:full-node allocated -
Specifying Filesystems
On ThetaGPU and other systems running Cobalt at the ALCF your job submission should specify which filesystems your will be using. In the event that a filesystem becomes unavailable, this information is used to preserve jobs that would use that filesystem while allowing other jobs that are not using an affected filesystem to proceed to run normally.
You may specify your filesystem by adding filesystems=<list of filesystems>
to the --attrs
argument of qsub in Cobalt. Valid filesystems are home
, eagle
, grand
, and theta-fs0
. The list is comma-delimited.
For example, to request the home
and eagle
filesystems for your job you would add filesystems=home,eagle
to your qsub
command. If this is not specified a warning will be printed and then the job will be tagged as requesting all filesystems and may be held unnecessarily if a filesystem is not currently available. The warnings are written to stderr of qsub
and qalter
commands that change the value of the --attrs
flag. Scripts that are parsing stderr from these utilities may encounter errors from the additional warnings if filesystems are not specified in these commands.
If a job is submitted while a filesystem it requested is marked down, the job will automatically be placed into a user_hold
status and a warning message will be printed, but the job will be otherwise queued. The job is also placed into admin_hold
status by a sysadmin script. Once the affected filesystem has been returned to normal operation, the admin_hold
is released. You are responsible for releasing the user_hold
once you receive the message that the affected filesystem has been returned to normal operation. The job cannot run until both the holds are released.
If a job requesting a filesystem that is marked down is already in the queue, it will be placed on admin_hold
status and will be released once the filesystem is operational.
qalter
. Note that qalter --attrs
is a replace and not an update operation. This means that you should once again specify all the attributes that you had in the original qsub
command.
To release user hold:
