Skip to content
Argonne Leadership Computing Facility
Python/C++ Code Interoperability
These are the steps to build code that has Python/C++ code interoperability.
Login to a ThetaGPU head node
ssh thetagpusn1
1. Request an interactive session on an A100 GPU
qsub -n 1 -q default -A datascience -I -t 1:00:00
Following this, we need to execute a few commands to get setup with an appropriately optimized TensorFlow. These are: 3. Activate the TensorFlow 2.2 Singularity container:
singularity exec -B /lus:/lus --nv /lus/theta-fs0/projects/datascience/thetaGPU/containers/tf2_20.08-py3.sif bash
2. Setup access to the internet
export HTTP_PROXY=http://theta-proxy.tmi.alcf.anl.gov:3128
export HTTPS_PROXY=https://theta-proxy.tmi.alcf.anl.gov:3128
Now that we can access the internet, we need to set up a virtual environment in Python (these commands should only be run the first time).
python -m pip install --user virtualenv
export VENV_LOCATION=/home/rmaulik/THETAGPU_TF_ENV # Add your path here
python -m virtualenv --system-site-packages $VENV_LOCATION
source $VENV_LOCATION/bin/activate
python -m pip install cmake
python -m pip install matplotlib
python -m pip install sklearn
cmake is required to build our C++ app and link to Python, and other packages may be pip installed as needed in your Python code. An example MakeLists.txt file for building with Python/C interoperability with examples can be found here.
