Skip to content
Argonne Leadership Computing Facility
TensorBoard Instructions
If you are able to install TensorBoard on your local machine, it is often easiest to copy the requisite files from ALCF file systems (via sftp, scp, Globus, etc.) to your local machine and run a TensorBoard there.
However, if that is not possible, or if you have many and/or large files that TensorBoard needs to process located on ALCF file systems, there are several ways to run a TensorBoard server remotely.
TensorBoard server on a ThetaGPU compute node
This approach can be useful to have TensorBoard analyze live training progress. After you have logged into ThetaGPU, and have an interactive job running, you'll need to know the name of one of your worker nodes so you can SSH to it.
PORT0=9991
PORT1=9992
PORT3=9993
# Select a theta login node N where N=[1-6] ssh -L $PORT0:localhost:$PORT1 $USER@thetaloginN.alcf.anl.gov
# after reaching thetaloginN
# Replace NN with your thetagpu worker node ssh -L $PORT1:thetagpuNN:$PORT3 $USER@thetagpusn1
# after reaching thetagpusn1
# login to worker node
ssh thetagpuNN
# now setup your tensorflow environment
# for instance run the conda setup.sh script created during the install_tensorflow.sh script
# now run tensorboard
tensorboard --logdir </path/to/logs> --port $PORT3 --bind_all
TensorBoard server on a ThetaKNL login node
If you do not require the use of a GPU during analysis while TensorBoard runs, and you do not require a cutting-edge version of TensorBoard (this will load version 2.6.0), you can avoid additional SSH tunnel hops by running the TensorBoard server on a ThetaKNL login node:
ssh -D <some-port-number>  theta.alcf.anl.gov
module load conda/2021-09-22
export LD_LIBRARY_PATH=/soft/thetagpu/cuda/cuda_11.3.0_465.19.01_linux/lib64:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/soft/thetagpu/cuda/cuda_11.3.0_465.19.01_linux/extras/CUPTI/lib64/:$LD_LIBRARY_PATH
