ALCF File Systems¶
Our HPC systems store project data in file systems called Eagle and Flare. Eagle and Flare are Lustre file systems mounted as /eagle
and /flare
, respectively. For more information on the Lustre file systems, here is a document on Lustre File Striping Basics.
For information on the AI Testbed storage systems, refer to the AI Testbed storage page: https://argonne-lcf.github.io/ai-testbed-userdocs/common/storage/
Our HPC systems also mount a Lustre home file system, either agile-home or gecko-home. The home file system is mounted as /home
and should generally be used for small files and any binaries to be run on Polaris or Aurora. The performance of this file system is reasonable, but using it for intensive I/O from the compute nodes is discouraged because I/O from the compute nodes uses the project data file systems, which are fast parallel systems and have far more storage space and greater I/O performance than the home directory space.
The agile-home file system is regularly backed up to tape. The data file system is not backed up. It is the user’s responsibility to ensure that copies of any critical data on the data file system have either been archived to tape or stored elsewhere.
Name | Accessible From | Type | Path | Production | Backed-up | Usage |
agile-home | Polaris | Lustre | /home or /lus/agile/home | Yes | Yes | General use |
eagle | Polaris | Lustre | /eagle or /lus/eagle/projects | Yes | No | Community sharing via Globus; Intensive job output, large files |
Node SSD (Compute node only) | Polaris | xfs | /local/scratch | Yes | No | Local node scratch during run |
gecko-home | Aurora | Lustre | /home or /lus/gecko/home | Yes | No | General use |
flare | Aurora | Lustre | /flare or /lus/flare/projects | Yes | No | Community sharing via Globus; Intensive job output, large files |
Available Directories¶
Home Directories¶
- Created when an account is created
- Located under /home
- Each home directory is subject to a quota based on user file ownership. The default quota is 50 GB
Sharing Home Directory Files or Subdirectories with Others¶
If you need to share files or subdirectories (folders) under your home directory with collaborators (other ALCF users), you need to change file permissions from their defaults. You must change permissions of your top-level /home/username
directory, even if you only want to share certain files/directories within it. Using normal Linux file permissions control is good enough to give access to all other users and is simple. For more fine-grained control over specific users, you need to use Linux access control list (ACL) commands.
Simple Method: Permission to All Users¶
First, a one-time-only change to your top-level /home/username
directory.
Then you may permission individual files and/or subdirectories with read access. For example, to recursively change permissions on /home/username/subdirectoryname
so that all files in that subdirectory and any subdirectory trees within it are world-readable, you would use
Refined Method: Use ACL to Give Permission to Specific Users¶
directory. To share files/directories with user gilgamesh, for example:
so that all files in that subdirectory and any subdirectory trees within it are readable to user gilgamesh, you would use
Project Directories¶
- Directories on Eagle or Flare are created when an allocation (INCITE, ALCC, Discretionary, etc.) is awarded. Directories can be created as stand-alone allocations. Use the allocation request form to submit requests for an allocation on Eagle.
- Directory paths:
- Eagle:
/eagle
or/lus/eagle/projects
- Flare:
/flare
or/lus/flare/projects
- Eagle:
These project spaces do not have user quotas but a directory quota, meaning that ALL files contained within a project directory, regardless of the username, cannot exceed the disk space allocation granted to the project. For more information on quotas, see the Disk Quota page.
Local Node SSD¶
Access to SSDs is enabled by default on Polaris.
SSD Information¶
- Local scratch SSD storage on compute nodes for running jobs
- Completely local non-parallel filesystem
- Located at /local/scratch on Polaris computes
- Wiped between Cobalt/PBS Pro jobs
- No automatic backups provided
- Information on the current SSD drives in use is below:
Polaris SSD Specs
Model PM1725a drives specifications
Model PM1725a drives | ------- |
Capacity | 1.6 TB |
Sequential Read | 3300 MB/s |
Sequential Write | 3300 MB/s |
