Disk Quota¶
Overview¶
Disk quotas are enabled on project directories. ALCF's HPC systems use the agile-home file system located at /lus/agile/home
, where quotas are also enforced. Details on the home file system are listed in file systems. Below are descriptions and examples for the home file system, as well as the Eagle project filesystems.
Home Directory Quotas¶
By default, each home directory is assigned a quota of 50 GB. File ownership determines disk space usage.
To check the home directory usage, enter this command:
Name Type Filesystem Used Quota Grace
userX User /lus/agile 44.13G 50.00G none
Project Directory Quotas¶
The amount of data stored under /lus/grand/projects/PROJECT_NAME
cannot exceed the approved project quota limit set during the allocation period. The total data usage under the project directory is used to calculate the disk quota.
To check project quota usage on the file systems, enter this command:
Lustre : Current Project Quota information for projects you're a member of:
projectX Project eagle 1.87T 1000T -
Requesting a New Eagle Allocation¶
To request a new project with an allocation on Eagle (with or without a compute allocation), please fill out the Director's Discretionary allocation form. Note that all new compute projects will have the default file system.
Extending a Quota¶
If you need to extend an expiring quota for your project directory, please send an email to [email protected] with the project name, filesystem, requested extension length, and reason for the extension.
Quota Increases¶
If you need a quota increase for your project directory, please send an email to [email protected] with the project name, filesystem, new quota amount, and reason for the increase.
