Skip to content
Argonne Leadership Computing Facility
Tunneling and Forwarding Ports
Port forwarding is covered here. This is specifically for TensorBoard.
TensorBoard Port Forwarding
This section describes the steps to be followed to set up port forwarding for applications, like TensorBoard, which runs on the SambaNova system and binds to one or more ports. This example uses 6006 and 16006 as port numbers. Using port numbers other than these may avoid collisions with other users.
From Your Local Machine
Replace ALCFUserID with your ALCF User ID.
Run
# Forward a port number from sambanova.alcf.anl.gov to your local machine.
ssh -v -N -f -L localhost:16006:localhost:16006 ALCFUserID@sambanova.alcf.anl.gov
Password: < MobilePass+ code >
# Connect to sambanova.alcf.anl.gov
ssh ALCFUserID@sambanova.alcf.anl.gov
From sambanova.alcf.anl.gov
Below are the commands specific to sn30-r1-h1. You may replace sn30-r1-h1 with any other node when using the appropriate system.
Run
NOTE: The full name is sn30-r1-h1.ai.alcf.anl.gov and it may also be used.
# Forward the port.
ssh -N -f -L localhost:16006:localhost:6006 ALCFUserID@sn30-r1-h1
# Connect to the system.
ssh ALCFUserID@sn30-r1-h1
On sn30-r1-h1
Activate the venv appropriate to your project.
Navigate to the appropriate directory for your model. Launch your model using srun or sbatch.
cd /path/to/your/project
sbatch --output=pef/my_model/output.log submit-my_model-job.sh
On Another sn30-r1-h1 Terminal Window
The SambaNova system has a bash shell script to setup the required software environment. This sets up the SambaFlow software stack, the associated environmental variables and activates a pre-configured virtual environment.
Use the command appropriate for your environment.
For example, if you are using LogReg:
ALCFUserID@sn30-r1-h1:~$ source /opt/sambaflow/apps/starters/logreg/venv/bin/activate
(venv) ALCFUserID@sn30-r1-h1:~$
tensorboard --logdir /logs --port 6006
Browser on Local Machine
Then, navigate in your browser to, in this example, http://localhost:16006 on your local machine.
Notes
Explanation of ssh command:
-N : no remote commands
-f : put ssh in the background
-L <machine1>:<portA>:<machine2>:<portB> :
The full command line will forward <machine2>:<portB> (remote scope) to <machine1>:<portA> (local scope)
Adapted from: How can I run Tensorboard on a remote server?
