Skip to content
Argonne Leadership Computing Facility
Job Queueing and Submission
Introduction
SambaNova uses Slurm for job submission and queueing. Below are some of the important commands for using Slurm. For more information refer to Slurm Documentation.
NOTE: Run the Python scripts using 'srun' or 'sbatch', to ensure that concurrent jobs do not interfere with each other.
NOTE: There is just one scheduler for all of the SambaNova nodes, e.g., sn30-r4-h2.
SRun
The Slurm command srun can be used to run individual Python scripts in parallel with other scripts on a cluster managed by Slurm. Examples of srun usage are shown below.
Slurm will assign a nodelist/host to run a job if a host is not specified.
Example:
srun python lenet.py compile -b=1 --pef-name="lenet" --output-folder="pef"
srun python lenet.py run --pef="pef/lenet/lenet.pef"
You may specify which node/host on which to run a job.
Reasons to specify a node list:
  • One wants to test a specific node to verify the function of the HW and SW (daily smoke tests do this)
  • The nodes are at different software levels and one wants to use a node that has the needed software level for one's application.
Example:
srun --nodelist=sn30-r1-h1 python lenet.py compile -b=1 --pef-name="lenet" --output-folder="pef"
SBatch
Alternatively, these jobs can be submitted to the Slurm workload manager through a batch script by using the sbatch command. To do this, create a bash script (submit-lenet-job.sh here as an example) with the commands that you want to execute.
#!/bin/sh
Then pass the bash script as an input to the sbatch command as shown below.
sbatch --output=pef/lenet/output.log submit-lenet-job.sh
In case of the need to use multiple RDUs (2 in the example shown below), the sbatch command would be altered as:
sbatch --gres=rdu:2 <your_script.sh>
SQueue
The squeue command provides information about jobs located in the Slurm scheduling queue.
squeue
SInfo
SInfo is used to view partition and node information for a system running Slurm.
Here is a suggested command:
sinfo -O AllocNodes, GresUsed, Gres, NodeList
For more information, see SInfo.
SCancel
SCancel is used to signal or cancel jobs, job arrays, or job steps.
scancel job_id
