Steps to Run BERT-Large on Sambanova DataScale SN10-8R
- BERT Code is in the Bert directory here for your reference.
- transformners_hook.py: contains code for BERT.
Pretraining in data parallel mode
Note: for the sake of the tutorial, we have precompiled the model and lowered the number of train steps to reduce the execution time.
- Create a folder for pretraining in your home repo, and copy the bash script
/projects/aitestbed_training/SN/precompiled_bert/bash_scripts/submit-bert-pretrain-job-LBS1024.sh
to it. Then, go to that folder. Example:
cd $HOME
mkdir pretrain
cp /projects/aitestbed_training/SN/precompiled_bert/bash_scripts/submit-bert-pretrain-job-LBS1024.sh pretrain/
cd pretrain/
- Open the
file, and changeOUTDIR
to location of the pretrain folder. Example:
Note: the per device batch size (LBS) is set to 1024 here. Also, the number of steps is set to 100, but this can be changed.
- SambaNova uses SLURM for job submission and queueing. We will use sbatch to submit our job to the job scheduler. Please refer to Sambanova Documentation for further details. In the following example, 2 RDUs are used:
sbatch --output=log_bert_pretrain_LBS1024_np2.out --gres=rdu:2 -c 8 submit-bert-pretrain-job-LBS1024.sh
-c
represents the number of cores per task
You can follow the status of your job using:
squeue
. The job should take about 8 min to complete. -
Once the job is completed, you can see the checkpoint(s) and accuracy metrics in
hf_output_lrg_run/
. The throughput is outputted in thelog_bert_pretrain_LBS1024_np2.out
file (search for throughput in the file).Click for sample throughput
Measuring peformance with world size: 2 initial run starts. initial run completes. e2e_latency: 30.75621747970581 seconds, throughput: 665.8816225861821 samples/s, measured over 10 iterations. NOTE: This is the combined throughput for 2 workers total duration: 30.75621747970581 s
Click for sample train_steps.txt
Click for sample step_loss.txt
Fine-tuning for question answering using 1 RDU
Note: for the sake of the tutorial, we have precompiled the model and lowered the number of train steps to reduce the execution time. We will also use a processed dataset.
- Create a folder for finetuning in your home repo, and copy the bash script
/projects/aitestbed_training/SN/precompiled_bert/bash_scripts/submit-bert-squad-job.sh
cd $HOME
mkdir finetune
cp /projects/aitestbed_training/SN/precompiled_bert/bash_scripts/submit-bert-squad-job.sh finetune/
cd finetune/
Copy the processed dataset to the finetune repo. This will avoid tokenizing the dataset on the fly.
Open the
to location of the finetune folder. Example:
- SambaNova uses SLURM for job submission and queueing. We will use sbatch to submit our job to the job scheduler. Please refer to Sambanova Documentation for further details. In the following example, 1 RDU is used:
squeue
hf_output_squad_run/
.Click for sample log_history.json
[ { "exact": 54.33301797540208, "f1": 66.54507382283774, "epoch": 0.07965242577842144, "total_flos": 5419063617454080, "step": 220 } ]
Click for sample eval_results_squad.txt
Other Models and Use-cases
- Full execution scripts (compile, run, measure-perf) for BERT-Large can be found under
/projects/aitestbed_training/SN/full_execution_bert/bash_scripts
. submit-bert-pretrain-job.sh
: bash script for pretraining job with 8 RDUs and LBS=256-
: bash script for fine-tuning job for question answering with 1 RDU -
See Example Programs for instructions to run other well-known AI applications on SambaNova hardware (e.g., LeNet, FFN-MNIST, logistic regression, UNet)
