Job Queueing and Submission
Introduction
SambaNova uses Slurm for job submission and queueing. Below are some of the important commands for using Slurm. For more information refer to Slurm Documentation.
NOTE: Run the python scripts using srun or sbatch, to ensure that concurrent jobs do not interfere with each other.
NOTE: There is just one scheduler for both sm-01 and sm-02.
Srun
The Slurm command srun
can be used to run individual python scripts in parallel with other scripts on a cluster managed by Slurm. Examples of srun
usage are shown below.
Slurm will assign a nodelist/host to run a job if a host is not specified.
Example:
srun python lenet.py compile -b=1 --pef-name="lenet" --output-folder="pef"
srun python lenet.py run --pef="pef/lenet/lenet.pef"
You may specify which node/host on which to run a job.
Reasons to specify a node list:
- One wants to test a specific node to verify function of the HW and SW (daily smoke tests do this)
- The nodes are at different software levels and one wants to use a node that has the needed software level for one's application.
Example:
Sbatch
Alternatively, these jobs can be submitted to the Slurm workload manager through a batch script by using the sbatch
command. To do this, create a bash script (submit-lenet-job.sh here as an example) with the commands that you want to execute.
#!/bin/sh
Then pass the bash script as an input to the sbatch
command as shown below.
In case of the need to use multiple RDUs (2 in the example shown below), the sbatch
command would be altered as:
Squeue
The squeue
command provides information about jobs located in the Slurm scheduling queue.
Sinfo
Sinfo is used to view partition and node information for a system running Slurm.
Here is a suggested command:
For more information, see sinfo.
Scancel
Scancel is used to signal or cancel jobs, job arrays, or job steps.
