Example Multi-Node Programs
SambaNova provides examples of some well-known AI applications under the path: /opt/sambaflow/apps/starters
, on both SambaNova compute nodes. Make a copy of this to your home directory:
Copy starters to your personal directory structure if you have not already done so.
UNet
Set-up
Copy files and change directory if you have not already done so.
cp -r /opt/sambaflow/apps/image ~/apps/image
cd ~/apps/image
cp /software/sambanova/apps/image/pytorch/unet/*.sh .
You just copied two bash scripts. They are:
unet_all.sh
- Compiles UNet and then submits a batch job to run the model.
unet_batch.sh
- Runs Unet.
Unet All
Here is a breakdown of unet_all.sh.
The argument -x is used to specify that each executed line is to be displayed.
The second line is to stop on error.
Lastly, set total time, SECONDS, to zero.
Set variables.
Activate the virtual environment. And, establish the UNet directory.
Display model name and time.
This section will compile the model for multiple RDUs if it does not exist.
A log file will be created at compile_${BS}_${IM}_NN.log.
# Compile for parallel RDUs
if [ ! -e out/unet_train_${BS}_${IM}_NN/unet_train_${BS}_${IM}_NN.pef ] ; then
python ${UNET}/unet.py compile -b ${BS} --in-channels=3 --in-width=${IM} --in-height=${IM} --enable-conv-tiling --mac-v2 --compiler-configs-file ${UNET}/jsons/compiler_configs/unet_compiler_configs_no_inst.json --pef-name="unet_train_${BS}_${IM}_NN" --data-parallel -ws 2 > compile_${BS}_${IM}_NN.log 2>&1
fi
Here, a batch job is submitted for the multi-node run.
Sbatch argument definitions:
--gres=rdu:1
This indicates that the model fits on a single RDU.
--tasks-per-node 8
All eight RDUs per node are to be used. Valid options are 1 through 8.
--nodes 2
The number of nodes to use. Currently there are two nodes.
--nodelist sm-02,sm-01
The node names to use.
--cpus-per-task=16
CPUs per model.
unet_batch.sh
The bash script to be batched.
Unet_batch.sh argument definitions:
NN
Number of nodes.
# Run Multi-Node, Data Parallel
NN=2
echo "RUN"
echo "NN=${NN}"
sbatch --gres=rdu:1 --tasks-per-node 8 --nodes 2 --nodelist sm-02,sm-01 --cpus-per-task=16 ./unet_batch.sh ${NN} ${NUM_WORKERS}
echo "Duration: " $SECONDS
Unet Batch
Here is a description of unet_batch.sh. This script is automatically run by unet_all.sh.
This block is the same as above.
Establish variables.
# Batch Size
BS=256
# IMage size
IM=256
NN=${1}
NUM_WORKERS=${2}
export OMP_NUM_THREADS=16
DATADIR=/software/sambanova/dataset/kaggle_3m
UNET=$(pwd)/unet
export SAMBA_CCL_USE_PCIE_TRANSPORT=0
Activate virtual environment.
Display an informative banner.
Run Unet
srun --mpi=pmi2 python ${UNET}/unet_hook.py run --do-train --in-channels=3 --in-width=${IM} --in-height=${IM} --init-features 32 --batch-size=${BS} --epochs 2 --data-dir ${DATADIR} --log-dir log_dir_unet_${NN}_train_kaggle --pef=$(pwd)/out/unet_train_${BS}_${IM}_NN/unet_train_${BS}_${IM}_NN.pef --data-parallel --reduce-on-rdu --num-workers=${NUM_WORKERS}
Display total execution time.
Compile and Run
Change directory:
Compile and run UNet:
Squeue will give you the queue status.
