Skip to content
sbank Allocation Accounting System
sbank is the accounting system used within the ALCF. It tracks project allocations, usage charges, and refunds. sbank allows queries about the balance and expiration of project allocations.
The sbank accounting system helps users manage their allocations and usage per job. It gives PIs the ability to monitor their allocation usage by user, job, and machine. It also allows the user to monitor their usage per allocation and provides insight into how many hours are left on the project.
sbank Interface Options
sbank is available through a command line interface (see below for example commands and docs) or through a graphic interface in the MyALCF user portal further explained in MyALCF documentation.
Getting Started with sbank (Command Line)
To view examples of the most common sbank commands, please see sbank Example Commands.
sbank Man Pages
Use these sbank man pages to get information on how to use the commands.
