Manpage for sbank-list-projects¶
sbank-list-projects [options]¶
Generate project list report.
Notes:
- Use
-Ito include inactive allocations. - To get information for all resources, enter
-r all.
OPTIONS¶
--version¶
Show the program's version number and exit.
-h, --help¶
Show this help message and exit.
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID¶
Filter on allocation ID.
-f FIELD_INFO, --field-to-display=FIELD_INFO¶
FIELD_INFO is <FIELD>[:<WIDTH>]. For available fields, enter -f? or -f "?". To add fields, enter -f "+ <FIELD>[:<WIDTH>] ...".
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY¶
Set the number of fields to display.
-p PROJECT, --project=PROJECT¶
Filter on name or ID. DO NOT MIX. Enter 'all' to get all. Wildcards '*' are allowed but only on names.
-r RESOURCE, --resource=RESOURCE¶
Filter on name or ID. DO NOT MIX. Enter 'all' to get all. Wildcards '*' are allowed, but only on names.
-u USER, --user=USER¶
-w "FIELD_INFO", --field-width¶
"FIELD_INFO" is <FIELD>:<WIDTH>. For available fields, enter -w? or -w "?".
[OPER1]
Operator Defaults:
- OPER1 is 'lt' for a single date entry. OPER1 and OPER2 are 'ge' and 'lt', respectively, for a range date entry.
Date Parsing Precedence:
- YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012.
-H, --human-readable¶
Abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-I, --get-inactive¶
Get inactive allocations.
-S START, --start=START¶
[OPER1]
Operator Defaults:
--debug=DEBUG_LEVEL¶
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2
--all-charges¶
Only show list info that has charges regardless of project/user relationship.
--no-commas¶
Remove commas from comma-separated thousands.
--no-header¶
Do not display the header.
--no-rows¶
Do not display the row data.
--no-sys-msg¶
Do not display system messages.
--no-totals¶
Do not display the totals.
