Manpage for sbank-list-allocations¶
sbank-list-allocations [options]¶
Generate allocation list report.
Notes: 1. Use -I to include inactive allocations. 2. Enter -r all to get information for all resources.
OPTIONS¶
--version¶
Show program's version number and exit.
-h, --help¶
Show this help message and exit.
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID¶
Filter on allocation ID.
-c, --comment¶
Display comment.
-e EVENT_ID, --event-id=EVENT_ID¶
Filter on event ID.
-f FIELD_INFO, --field-to-display=FIELD_INFO¶
FIELD_INFO is <FIELD>[:<WIDTH>]. For available fields, enter -f? or -f "?". To add fields, enter -f "+ <FIELD>[:<WIDTH>] ...".
-j JOBID, --jobid=JOBID¶
Filter on job ID.
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY¶
Set number of fields to display.
-p PROJECT, --project=PROJECT¶
Filter on name or ID. DO NOT MIX. Enter all to get all. Wildcards * are allowed, but only on names.
-r RESOURCE, --resource=RESOURCE¶
-t TRANSACTION_ID, --transaction-id=TRANSACTION_ID¶
Filter on transaction ID.
-u USER, --user=USER¶
-w "FIELD_INFO", --field-width¶
FIELD_INFO is <FIELD>:<WIDTH>. For available fields, enter -w? or -w "?".
-E END, --end=END¶
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: - ge, gt, le, lt, eq or >=, >, <=, <, ==.
Operator Defaults:
- OPER1 is
ltfor single date entry. OPER1 and OPER2 aregeandlt, respectively, for range date entry.
Date Parsing Precedence:
- YEAR then MONTH then DAY, i.e.,
121101is parsed as YYMMDD, hence Nov. 1, 2012.
-H, --human-readable¶
Abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-I, --get-inactive¶
Get inactive allocations.
-O, --get-only-inactive¶
Only inactive allocations.
-S START, --start=START¶
Operator Defaults:
- OPER1 is
-T TRANSACTION_TYPE, --transaction-type=TRANSACTION_TYPE¶
Transaction types: CHARGE, REFUND, PULLBACK, DEPOSIT, VOID.
--award-type-name=AWARD_TYPE_NAME¶
Filter on award-type name.
--award-category=AWARD_CATEGORY¶
Filter on award category.
--cbank-ref=CBANK_REF¶
Filter on Clusterbank reference ID.
--created=CREATED_TIMESTAMP¶
Operator Defaults:
- OPER1 is
--debug=DEBUG_LEVEL¶
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2.
--get-deleted¶
Get deleted objects.
--get-only-deleted¶
Get only deleted objects.
--all-charges¶
Only show list info that have charges regardless of project/user relationship.
--last-updated=LAST_UPDATED_TIMESTAMP¶
Operator Defaults:
- OPER1 is
--no-commas¶
Remove commas from comma-separated thousands.
--no-header¶
Do not display the header.
--no-rows¶
Do not display the row data.
--no-sys-msg¶
Do not display system message.
--no-totals¶
Do not display the totals.
