Manpage for sbank-detail-transactions¶
sbank-detail-transactions [options] [ ... ]¶
Detail transaction information.
Note
- The list of
<transaction id>arguments is optional. - You can also enter the
<transaction id>list by using the-toption multiple times. - Regardless, both are optional, and you can get detailed transaction info using the option filters below.
OPTIONS¶
--version¶
Show the program's version number and exit.
-h, --help¶
Show this help message and exit.
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID¶
Filter on allocation id.
-c, --comment¶
Display comment.
-e EVENT_ID, --event-id=EVENT_ID¶
Filter on event id.
-f FIELD_INFO, --field-to-display=FIELD_INFO¶
FIELD_INFO is <FIELD>[:<WIDTH>]. For available fields, enter -f? or -f "?". To add fields, enter -f "+ <FIELD>[:<WIDTH>] ...".
-j JOBID, --jobid=JOBID¶
Filter on jobid.
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY¶
Set the number of fields to display.
-p PROJECT, --project=PROJECT¶
Filter on name or id. DO NOT MIX. Enter 'all' to get all. Wildcards '*' are allowed but only on names.
-r RESOURCE, --resource=RESOURCE¶
-t TRANSACTION_ID, --transaction-id=TRANSACTION_ID¶
Filter on transaction id.
-u USER, --user=USER¶
-w "FIELD_INFO", --field-width=¶
"FIELD_INFO" is <FIELD>:<WIDTH>. For available fields, enter -w? or -w "?".
-E JOB_END, --end=JOB_END¶
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following:
ge,gt,le,lt,eqor>=,>,<=,<,==.
Operator Defaults:
OPER1is 'ge' for a single date entry.OPER1andOPER2are 'ge' and 'lt', respectively, for range date entry.
Date Parsing Precedence:
- YEAR then MONTH then DAY, i.e.,
121101is parsed as YYMMDD, hence Nov 1, 2012.
-H, --human-readable¶
Abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-S JOB_START, --start=JOB_START¶
Operator Defaults:
-T TRANSACTION_TYPE, --transaction-type=TRANSACTION_TYPE¶
Transaction types: CHARGE, REFUND, PULLBACK, DEPOSIT, VOID.
--at=TRANSACTION_AT_TIMESTAMP¶
Operator Defaults:
--cbank-ref=CBANK_REF¶
Filter on Clusterbank reference id.
--created=JOB_CREATED_TIMESTAMP¶
Operator Defaults:
--debug=DEBUG_LEVEL¶
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2.
--no-commas¶
Remove commas from comma-separated thousands.
--no-header¶
Do not display the header.
--no-rows¶
Do not display the row data.
--no-sys-msg¶
Do not display system messages.
--no-totals¶
Do not display the totals.
--queued=JOB_QUEUED_TIMESTAMP¶
Operator Defaults:
