Manpage for sbank-detail-projects¶
sbank-detail-projects [options] [ ... ]¶
Detail project information.
NOTE: 1. The list of
OPTIONS¶
--version¶
show program's version number and exit
-h, --help¶
show this help message and exit
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID¶
filter on allocation id
-f FIELD_INFO, --field-to-display=FIELD_INFO¶
FIELD_INFO is
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY¶
set number of fields to display
-p PROJECT, --project=PROJECT¶
filter on name or id, DO NOT MIX, enter 'all' to get all, wild cards '*' is allowed but only on names
-r RESOURCE, --resource=RESOURCE¶
-u USER, --user=USER¶
-w "FIELD_INFO", --field-width¶
"FIELD_INFO" FIELD_INFO is
-E END, --end=END¶
[OPER1]
- ge, gt, le, lt, eq or >=, >, <=, <, ==.
Operator Defaults:
- OPER1 is 'lt' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry.
Date Parsing Precedence: - YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012
-H, --human-readable¶
abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-I, --get-inactive¶
get inactive allocations
-S START, --start=START¶
[OPER1]
Operator Defaults:
- OPER1 is 'ge' for single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry.
--debug=DEBUG_LEVEL¶
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2
--all-charges¶
only show list info that have charges regardless of project/user relationship
--no-commas¶
remove commas from comma separated thousands
--no-header¶
do not display the header
--no-rows¶
do not display the row data
--no-sys-msg¶
do not display system message
--no-totals¶
do not display the totals
