sbank-detail-jobs¶
sbank-detail-jobs [options] [ | ... | ]¶
Detail job information.
NOTE:
- The arguments
<jobid.resource>or<event_id>are NOT REQUIRED. event_idis the JOB DATABASE ID.<jobid>is the SCHEDULER CREATED ID, such as Cobalt.<jobid>can also be entered using the option-j <jobid>.<event_id>can also be entered using the option-e <event_id>.<resource>can also be entered using the option-r <resource>.- Regardless, you can use options or arguments to get detailed job information.
OPTIONS¶
--version
Show the program's version number and exit.
-h, --help
Show this help message and exit.
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID
Filter on allocation ID.
-e EVENT_ID, --event-id=EVENT_ID
Filter on event ID.
-f FIELD_INFO, --field-to-display=FIELD_INFO
FIELD_INFO is <FIELD>[:<WIDTH>]. For available fields, enter -f? or -f "?". To add fields, enter -f "+ <FIELD>[:<WIDTH>] ...".
-j JOBID, --jobid=JOBID
Filter on job ID.
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY
Set the number of fields to display.
-p PROJECT, --project=PROJECT
Filter on name or ID. DO NOT MIX. Enter 'all' to get all. Wildcards '*' are allowed but only on names.
-r RESOURCE, --resource=RESOURCE
-t TRANSACTION_ID, --transaction-id=TRANSACTION_ID
Filter on transaction ID.
-u USER, --user=USER
-w "FIELD_INFO", --field-width
"FIELD_INFO" is <FIELD>:<WIDTH>. For available fields, enter -w? or -w "?".
-E END, --end=END
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'lt' for a single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012.
-H, --human-readable
Abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions) ...
-S START, --start=START
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'ge' for a single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012.
-T TRANSACTION_TYPE, --transaction-type=TRANSACTION_TYPE
Transaction types: CHARGE, REFUND, PULLBACK, DEPOSIT, VOID.
--created=CREATED_TIMESTAMP
--debug=DEBUG_LEVEL
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2.
--eligible=ELIGIBLE_TIMESTAMP
--get-not-charged
Only un-charged jobs.
--history-date-range=END
--last-updated=LAST_UPDATED_TIMESTAMP
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following: ge, gt, le, lt, eq or >=, >, <=, <, ==. Operator Defaults: OPER1 is 'gt' for a single date entry, OPER1 and OPER2 are 'ge' and 'lt', respectively, for range date entry. Date Parsing Precedence: YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov. 1, 2012.
--no-commas
Remove commas from comma-separated thousands.
--no-header
Do not display the header.
--no-history
Do not show history information.
--no-rows
Do not display the row data.
--no-sys-msg
Do not display system messages.
--no-totals
Do not display the totals.
--queued=QUEUED_TIMESTAMP
