Manpage for sbank-detail-allocations¶
sbank-detail-allocations [options] [ ... ]¶
Detail allocation information.
NOTE: 1. The list of <allocation id> arguments is optional. 2. You can also enter <allocation id> list by using the -a option multiple times. 3. Regardless, both are optional, and you can get detailed allocation info using the option filters below.
OPTIONS¶
--version¶
Show the program's version number and exit.
-h, --help¶
Show this help message and exit.
-a ALLOCATION_ID, --allocation-id=ALLOCATION_ID¶
Filter on allocation id.
-e EVENT_ID, --event-id=EVENT_ID¶
Filter on event id.
-f FIELD_INFO, --field-to-display=FIELD_INFO¶
FIELD_INFO is <FIELD>[:<WIDTH>]. For available fields, enter -f? or -f "?". To add fields, enter -f "+ <FIELD>[:<WIDTH>] ...".
-j JOBID, --jobid=JOBID¶
Filter on jobid.
-n NUM_FIELDS_TO_DISPLAY, --num-fields-to-display=NUM_FIELDS_TO_DISPLAY¶
Set the number of fields to display.
-p PROJECT, --project=PROJECT¶
Filter on name or id. DO NOT MIX. Enter 'all' to get all. Wildcards '*' are allowed but only on names.
-r RESOURCE, --resource=RESOURCE¶
-t TRANSACTION_ID, --transaction-id=TRANSACTION_ID¶
Filter on transaction id.
-u USER, --user=USER¶
-w "FIELD_INFO", --field-width=¶
"FIELD_INFO" is <FIELD>:<WIDTH>. For available fields, enter -w? or -w "?".
-E END, --end=END¶
[OPER1]<UTC_DATE1>[...[OPER2]<UTC_DATE2>], where the operators OPER1 and OPER2 can be one of the following:
ge,gt,le,lt,eqor>=,>,<=,<,==.
Operator Defaults:
OPER1is 'ge' for single date entry.OPER1andOPER2are 'ge' and 'lt', respectively, for range date entry.
Date Parsing Precedence:
- YEAR then MONTH then DAY, i.e., 121101 is parsed as YYMMDD, hence Nov 1, 2012.
-H, --human-readable¶
Abbreviate numbers and use unit suffixes: K (thousands), M (millions), G (billions), T (trillions), ...
-I, --get-inactive¶
Also get inactive allocations.
-O, --get-only-inactive¶
Only inactive allocations.
-S START, --start=START¶
Operator Defaults:
-T TRANSACTION_TYPE, --transaction-type=TRANSACTION_TYPE¶
Transaction types: CHARGE, REFUND, PULLBACK, DEPOSIT, VOID.
--award-type-name=AWARD_TYPE_NAME¶
Filter on award type name.
--award-category=AWARD_CATEGORY¶
Filter on award category.
--cbank-ref=CBANK_REF¶
Filter on Clusterbank reference id.
--created=CREATED_TIMESTAMP¶
Operator Defaults:
--debug=DEBUG_LEVEL¶
SILENT, MUCH_LESS, LESS, MORE, VERBOSE, DEBUG, DEBUG1, DEBUG2.
--get-deleted¶
Also get deleted objects.
--get-only-deleted¶
Only deleted objects.
--all-charges¶
Only show list info that have charges regardless of project/user relationship.
--history-date-range=END¶
Operator Defaults:
--last-updated=LAST_UPDATED_TIMESTAMP¶
Operator Defaults:
--no-commas¶
Remove commas from comma-separated thousands.
--no-header¶
Do not display the header.
--no-history¶
Do not show history information.
--no-rows¶
Do not display the row data.
--no-sys-msg¶
Do not display system messages.
--no-totals¶
Do not display the totals.
